Topic: TotalMix/UFX instantly crashes
20" imac core 2 duo 2.16 4G 667Hz
10.5.8
UFX
All I have done is installed the driver and updated using 'Fireface USB Flash Update'
Currently showing
Revision USB 351/DSP 1.39/FW 340
Status Up-to-date
As soon as I power cycle after the update, Totalmix tried to open, it immediately crashed with the following 'Problem Details'
It tries to open, displays even hot inputs on the top analog of the matrix, I can literally see the meters working and then they freeze/stick and then it crashes...
Each subsequent attempt to open Totalmix, power cycle UFX results in the same immediate closing of Totalmix. I am at a loss and stuck
Thanks!!
Process: Totalmix [495]
Path: /Applications/Totalmix.app/Contents/MacOS/Totalmix
Identifier: de.rme-audio.TotalmixFX
Version: 0.93 MAC OS X (0.93 MAC OS X)
Code Type: X86 (Native)
Parent Process: launchd [181]
Interval Since Last Report: 617 sec
Crashes Since Last Report: 3
Per-App Interval Since Last Report: 12 sec
Per-App Crashes Since Last Report: 3
Date/Time: 2011-08-22 17:57:28.195 -0500
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: CB65B039-E93E-41A8-9F51-370CA58EEE67
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0
Thread 0 Crashed:
0 de.rme-audio.TotalmixFX 0x00016ee3 CDevSettings::ChangeParam(PARAM*, float, int, int, bool) + 403
1 de.rme-audio.TotalmixFX 0x0002a531 CDevSettings::ReceiveDeviceParams() + 2513
2 de.rme-audio.TotalmixFX 0x0002ab5e TimerActionDevSettings(__EventLoopTimer*, void*) + 126
3 com.apple.CoreFoundation 0x9805a8f5 CFRunLoopRunSpecific + 4469
4 com.apple.CoreFoundation 0x9805aaa8 CFRunLoopRunInMode + 88
5 com.apple.HIToolbox 0x9046a2ac RunCurrentEventLoopInMode + 283
6 com.apple.HIToolbox 0x9046a0c5 ReceiveNextEventCommon + 374
7 com.apple.HIToolbox 0x904c8b56 _AcquireNextEvent + 58
8 com.apple.HIToolbox 0x904c72b3 RunApplicationEventLoop + 207
9 de.rme-audio.TotalmixFX 0x00042494 main + 772
10 de.rme-audio.TotalmixFX 0x000028d6 start + 54
Thread 1:
0 libSystem.B.dylib 0x902d3166 mach_msg_trap + 10
1 libSystem.B.dylib 0x902da95c mach_msg + 72
2 com.apple.CoreFoundation 0x98059e7e CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x9805aaa8 CFRunLoopRunInMode + 88
4 com.apple.audio.CoreAudio 0x93d0a5f8 HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x93d0a480 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x90304055 _pthread_start + 321
7 libSystem.B.dylib 0x90303f12 thread_start + 34
Thread 2:
2 com.apple.audio.midi.CoreMIDI 0x000b0f0f XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
3 com.apple.audio.midi.CoreMIDI 0x000a3477 MIDIInPortThread::Run() + 111
4 com.apple.audio.midi.CoreMIDI 0x000a707d XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x000b19ee CAPThread::Entry(CAPThread*) + 96
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000889 ebx: 0xffffffff ecx: 0x00000000 edx: 0x000000b9
edi: 0x0c5e3000 esi: 0x00000000 ebp: 0xbfffe248 esp: 0xbfffe200
ss: 0x0000001f efl: 0x00010286 eip: 0x00016ee3 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x77fe7 +de.rme-audio.TotalmixFX 0.93 MAC OS X (0.93 MAC OS X) <178e8ce732cd5f955f89504e848d8f66> /Applications/Totalmix.app/Contents/MacOS/Totalmix
0x9f000 - 0xbcff7 com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xd4000 - 0xf2fe3 libexpat.1.dylib ??? (???) <eff8a63a23a7d07af62b36fdb329e393> /usr/lib/libexpat.1.dylib
0x209000 - 0x20cfff com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <51c811377017028f8904ad779e6a1344> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x212000 - 0x218fff com.apple.audio.AppleHDAHALPlugIn 1.7.1 (1.7.1a2) <a0a4389b5ac52ab84397d2b25c9d3b9c> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x7e8000 - 0x7f1ff7 com.apple.iokit.IOUSBLib 3.4.9 (3.4.9) <ea4061ec718fddebf2cf952e8606ae87> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0xc99f000 - 0xcc98ff3 com.apple.RawCamera.bundle 2.3.0 (505) <1c7cea30ffe2b4de98ced6518df1e54b> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
0x9006d000 - 0x9006dffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9006e000 - 0x900fbff7 com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x900fc000 - 0x90102fff com.apple.print.framework.Print 218.0.3 (220.2) <8c541d587e4068a5fe5a5ce8ee208516> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90104000 - 0x90131feb libvDSP.dylib ??? (???) <f39d424bd56a0e75d5c7a2280a25cd76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x90132000 - 0x9015dfe7 libauto.dylib ??? (???) <4f3e58cb81da07a1662c1f647ce30225> /usr/lib/libauto.dylib
0x9015e000 - 0x901f1ff3 com.apple.ApplicationServices.ATS 3.8 (???) <e61b0945da6ab368348a927f7428ad67> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9023e000 - 0x90253ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x90254000 - 0x902d1fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x902d2000 - 0x90439ff3 libSystem.B.dylib ??? (???) <be7a9fa5c8a925578bddcbaa72e5bf6e> /usr/lib/libSystem.B.dylib
0x9043a000 - 0x90742fe7 com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90743000 - 0x90794ff7 com.apple.HIServices 1.7.1 (???) <ba7fd0ede540a0da08db027f87efbd60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x90795000 - 0x907b1ff3 com.apple.CoreVideo 1.6.1 (48.6) <186cb311c17ea8714e918273c86d3c13> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x907b2000 - 0x907e9fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <41d5aeffefc6d19d471f51ae0b15024f> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x908b4000 - 0x908fdfef com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x908fe000 - 0x9090effc com.apple.LangAnalysis 1.6.5 (1.6.5) <d057feb38163121ffd871c564c692804> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9090f000 - 0x9091cfe7 com.apple.opengl 1.5.10 (1.5.10) <e7d1198d869f45f09251f9697cbdd192> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9091d000 - 0x90929ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9092a000 - 0x9094efff libxslt.1.dylib ??? (???) <c372568bd2f7169efa0faee6546eead3> /usr/lib/libxslt.1.dylib
0x90ad0000 - 0x90e8efea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90e8f000 - 0x90f5afef com.apple.ColorSync 4.5.4 (4.5.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91056000 - 0x91071ff3 libPng.dylib ??? (???) <e0c3bdc3144e1ed91f1e4d00d147ff3a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91078000 - 0x9107ffe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x911cb000 - 0x911d2ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x912ea000 - 0x912effff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x912f0000 - 0x91331fe7 libRIP.A.dylib ??? (???) <cd04df9e8993c51312c8cbcfe2539914> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91488000 - 0x914e4ff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x914e5000 - 0x914f5fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <9a71429c74ed6ca43eb35e1f78471b2e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x914f6000 - 0x914f6fff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x914f7000 - 0x915beff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x916dd000 - 0x916ddffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x916de000 - 0x919b8ff3 com.apple.CoreServices.CarbonCore 786.16 (786.16) <d2af3f75c3500c518c39fd00aed7f9b9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x919b9000 - 0x919c2fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91a1c000 - 0x91a76ff7 com.apple.CoreText 2.0.5 (???) <5483518a613464d043455ac661a9dcbe> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x91c45000 - 0x91d2dff3 com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x91d3e000 - 0x91de5fec com.apple.CFNetwork 438.16 (438.16) <0a2f633dc532b176109547367f209ced> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91e65000 - 0x91e6ffeb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x91e70000 - 0x91efaff7 com.apple.DesktopServices 1.4.9 (1.4.9) <f5e51a76d315798371b3dd35a4d46d6c> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91efb000 - 0x91f54ff7 libGLU.dylib ??? (???) <64d010e31d7596bd8f9edc6e027d1d0c> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x91ffa000 - 0x92018fff libresolv.9.dylib ??? (???) <0e26b308654f33fc94a0c010a50751f9> /usr/lib/libresolv.9.dylib
0x92019000 - 0x92076ffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x92077000 - 0x9208dfff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x920be000 - 0x920caff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x9225b000 - 0x9229dfef com.apple.NavigationServices 3.5.2 (163) <7f4f1766414a511bf5bc68920ac85a88> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9229e000 - 0x922a0ff5 libRadiance.dylib ??? (???) <73169d8c3fc31df4005e8eaa0d16bde5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x92304000 - 0x9232dfff libcups.2.dylib ??? (???) <2b0ab6b9fa1957ee940835d0cfd42894> /usr/lib/libcups.2.dylib
0x9232e000 - 0x92480ff3 com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92481000 - 0x92533ffb libcrypto.0.9.7.dylib ??? (???) <d02f7e5b8a68813bb7a77f5edb34ff9d> /usr/lib/libcrypto.0.9.7.dylib
0x926b9000 - 0x926c4fe7 libCSync.A.dylib ??? (???) <f3228c803584320fde5e1bb9f04b4d44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x926c5000 - 0x926c5ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x926c6000 - 0x926c6ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x926c7000 - 0x92706fef libTIFF.dylib ??? (???) <2afd7f6079224311d67ab427e10bf61c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x92707000 - 0x92786ff5 com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x927c9000 - 0x92803fe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92804000 - 0x92808fff libGIF.dylib ??? (???) <ade6d93abe118569a7a39d11f81eb9bf> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x92809000 - 0x92811fff com.apple.DiskArbitration 2.2.1 (2.2.1) <ba64dd6ada417b5e7be736957f380bca> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92812000 - 0x92baffef com.apple.QuartzCore 1.5.8 (1.5.8) <18113e06d296230d63a63b58baf35f55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x93a4f000 - 0x93c20fef com.apple.security 5.0.7 (1) <44e26a9c40630a54d5a9f70c18483411> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93c21000 - 0x93c24fff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93c25000 - 0x93cccfeb com.apple.QD 3.11.57 (???) <35f058678972d42b88ebdf652df79956> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x93cea000 - 0x93cecfff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93ced000 - 0x93d6afeb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93d6b000 - 0x93df8ff7 com.apple.LaunchServices 292 (292) <a41286c7c1eb20ffd5cc796f791070f0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93e3e000 - 0x944defff com.apple.CoreGraphics 1.409.8 (???) <25020feb388637ee860451c19b613c48> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x944df000 - 0x94559ff8 com.apple.print.framework.PrintCore 5.5.4 (245.6) <9ae833544b8249984c07544dbe6a97fa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9456c000 - 0x9461dfff edu.mit.Kerberos 6.0.15 (6.0.15) <28005ea82ba82307f185c255c25bfdd3> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x947db000 - 0x947dbffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x947dc000 - 0x947f4fff com.apple.openscripting 1.2.8 (???) <a888b18c8527f71629702ed8dce9c877> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x956f6000 - 0x956f7ffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x956f8000 - 0x957d9ff7 libxml2.2.dylib ??? (???) <f274ba384fb55203873f9c17569ef131> /usr/lib/libxml2.2.dylib
0x9582c000 - 0x9583affd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x95853000 - 0x95891fff libGLImage.dylib ??? (???) <2e570958595e0c9c3a289158223b39ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95b33000 - 0x95b33ff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x95b76000 - 0x95b76ffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95b77000 - 0x95df3fe7 com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95dfa000 - 0x965f8fef com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x965f9000 - 0x9668cfff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x96700000 - 0x96b10fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x96b11000 - 0x96b30ffa libJPEG.dylib ??? (???) <6d61215d5adfd74f75fed2e4db29a21c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x96b31000 - 0x96b38ff7 libCGATS.A.dylib ??? (???) <8875cf11c0de0579423ac6b6ce80336d> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x96b39000 - 0x96b68fe3 com.apple.AE 402.3 (402.3) <dba512e47f68eea1dd0ab35f596edb34> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x96cc6000 - 0x96d4dff7 libsqlite3.0.dylib ??? (???) <aaaf72c093e13f34b96e2688b95bdb4a> /usr/lib/libsqlite3.0.dylib
0x96d4e000 - 0x96d52fff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x974ae000 - 0x97569fe3 com.apple.CoreServices.OSServices 228.1 (228.1) <9c640e79ad97f335730d8a49f6cb2032> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9756a000 - 0x976a3ff7 libicucore.A.dylib ??? (???) <f2819243b278259b9a622ea111ea5fd6> /usr/lib/libicucore.A.dylib
0x978bc000 - 0x97d8dfbe libGLProgrammability.dylib ??? (???) <d5cb4e7997a873cd77523689e6749acd> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x97d8e000 - 0x97e6efff libobjc.A.dylib ??? (???) <3ca288b625a47bbcfe378158e4dc328f> /usr/lib/libobjc.A.dylib
0x97e6f000 - 0x97fb8ff7 com.apple.ImageIO.framework 2.0.9 (2.0.9) <717938c4837f88bbe8ec613d4d25bc52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x97fbe000 - 0x97fe6ff7 com.apple.shortcut 1.0.1 (1.0) <37e4b08cfaf9edb08b8682a06c4ec844> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x97fe7000 - 0x9811afe7 com.apple.CoreFoundation 6.5.7 (476.19) <a332c8f45529ee26d2e9c36d0c723bad> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
