Topic: How to make TotalMix FX startup minimized to tray ?
was searching the forum but couldn't find similar problem.
How to make TotalMix FX startup minimized ?
Every time windows start i'm getting TotalMix FX window opened on my screen.
It's really annoying.
Please let me know how to solve this.
Re: How to make TotalMix FX startup minimized to tray ?
Mac? Windows? Updated drivers from non FX version?
Windows 7 x64 SP1. The problem appeared after installing newest drivers for Fireface UC, had no other soundcard on my system before.
There is a readme file in the newest driver which explains what to do when updating from an older driver that had no TotaMix FX. You have two entries in the reg for autostart TM...
I'll check my registry in several hours for autostart section. But i've applied .reg file every time during drivers update.
Okay, here is how my registry run section looks for RME Fireface UC:
TotalMix FX startup
7
If there is no other entry then you must have it in the standard Autostart menu of Windows as well. TM FX does not open its window without being called two times.
Thanks, will check other sources for possible startup
Okay, i've checked other sources by deleting Totalmix FX entry from registry. After rebooting my PC it didn't start at all. So i've just added the shortcut to TotalMixFx.exe to my autorun folder at windows start menu. And it works fine now, starts minimized to tray.
Maybe this will help, if someone will get same issue.
Thanks.
10
Remove that Autorun folder entry and simply reinstall (without removing it first) the latest driver. See manual on 'Driver Update' how to do this. Then the one and only correct RUN entry will be in the registry.
