Topic: Problem with Neutrik Firewire Chassis Connector
First please forgive my bad english.
I decided to rack my FF800 and wire most of the connections on a rear rack panel. I mounted a Neutrik Firewire Chassis Connector http://www.neutrik.com/fl/en/dataconnec … etail.aspx and plugged my FF800 from my PC through this Neutrik connector with two firewire cables but now I get many dropouts when I play audio.
I tried different firewire câbles, I tried to detach the Neutrik connector from the panel (I thought it was a ground problem), but it didn't fix anything.
Do you think this Neutrik connector is faulty or what I want to do is impossible ?
