Topic: FF800 and outboard gear
Hiya,
I use a FF800 with a PC, I have been using software plugins for mixing, and thought about using other products. I have seen the TK Audio BC1 in action and it sounds fantastic compared to some other compressors i have seen and to what i use plugin wise.
I have never used any outboard gear before, so is it possible to run the TK Audio BC1 through the FF800 and into my Daw or do I need something else to be able to use this ? Also if I can just use my FF800 what would i need to connect it all up ?
Thankyou for any help i get, i have spent a while trying to find out but not got anywhere.
Kind Regards
LP1982
Re: FF800 and outboard gear
A lot is going to depend on what DAW software you use to record and edit audio, which you did not mention in your post. You also did not mention how you intend to use the BC1 - to process input while recording, or to process already recorded material (or both). I would recommend that you re-read the Fireface manual dealing with signal routing and connections, pages 51 and 53, and with Totalmix, pages 51 - 77. There are also some informative videos online at YouTube dealing with making connections to and from the Fireface 800.
If you intend to use the BC1 to compress incoming audio prior to recording it, then you simply insert it between your mic pre-amp(s) and the Fireface. Of course, if you are using the Fireface's pre-amps, then you will need to use TotalMix to route the signal through to one or two of the Fireface outputs, which are then connected to the BC1 inputs, then routing the BC1 outputs to two Fireface inputs and thence to your DAW.
If you intend to use the compressor on material that is already recorded, then you need to route audio out of your DAW to one or two of the Fireface's outputs - use TRS to whatever the BC1 uses for connectors (XLR or TRS). Then route the output of the BC1 back into two inputs of the Fireface, and then use your DAW software to route the compressed audio to your main mix bus.
Making a round trip loop with this audio will introduce some processing latency (delay) to the audio you're processing, since it is passing through the Fireface D/A converter on the way out, and then through the A/D converter on the way back in. This is in addition to what processing delay the BC1 introduces, if any. You will need to determine this amount of time, and adjust your DAW's Latency Compensation so that it introduces this amount of compensation to everything that is not passing through the BC1, so that everything lines up.
In the Pyramix DAW, which I use, there is a handy little plug-in which is designed specifically for routing signal to and from an external piece of equipment. In it, you can determine the inputs and outputs of the Fireface to use, as well as what Latency Compensation needs to be applied. Surely other DAWs have something similar...
If you intend to use the external side chain input of the BC1, you need a Y cable with TS connectors on the two ends of the "Y", which get combined to a stereo TRS connector on the other end, like the second one shown in the manual on page 97. This will allow you to send stereo material from two outputs of the Fireface to the BC1's external side chain input.
Frank Lockwood
https://LockwoodARS.com
Fireface 800, Firmware 2.77
Hiya Frank,
Thankyou very much for your reply excellent info, much appreciated.
I use Sonar 8.5 at the mo but im prob going to upgrade to Sonar x1 pretty soon. I would use the BC1 for material that is already recorded.
Im not sure if there is anything in sonar like in pyramix DAW as i havnt checked as i havnt got or used any outboard gear before, to do with latency compensation. Would this be a problem if i ran a whole mix through it or just for indvidual tracks ?
Im still hunting down my FF800 manual lol
Thankyou again for your lengthy response, it was exactly the info i was looking for :-)
Kind Regards
LP1982
Hi LP1982,
Most current DAWs have the ability to deal with external effects processors in the signal chain.
In Sonar it is called External Inserts and in Cubase it is called External FX.
Sonar 8 and higher as well as Cubase 4 and higher have this feature.
They are both described in the user manuals.
Thanks Chris
Chris Ludwig
North East USA Sales | Synthax/RME
www.facebook.com/RMEAmericas
Twitter @RMEAmericas
5 (edited by fl 2011-09-05 04:20:12)
Amazing thing, Google...
http://forum.cakewalk.com/tm.aspx?m=227 … mpensation
http://www.cakewalk.com/Support/kb/reader.aspx/20090222
Frank Lockwood
