Topic: Multiface II - No Sound
This probably is not the soundcards fault but anyway, maybe someone can help.
I have two Multiface II / PCIe and experierence the following Problems:
It started with not having any sound with Ableton Live. Even with having sound on the master being routed to channels 1 & 2 on the first MF I will not see any signal on total mix and not hear any sound. When changing the sample rate in Ableton i get sound for really short (<1s) then there is no sound again. This results in either it is owrking at some point and keeps on working for a while or i get an echo sound that won't dissappear but change when changing the sample rate.
I do get the same results with cubase but wavelab works fine as well as playing files with media player does.
Any ideas?
W10 Pro x64, Reaper, Wavelab
5x MF II, 5x MF
E-mus and many other animals
