Topic: Total Mix & Cubase 5 Setup
I bought a Fireface a few days ago.
I work with hardware Synths and Cubase, so I generated inputs mono in 1, 2, ... in Cubase for the Synths and created Audio Channels. The signal mono In is routed to Audio 1, 2 ... . I receive Signal, but if I add insert effects, I can not listen to them, while playing a Synth.
Recording is no problem. Then adding effects is well.
Could there be a problem with the routing in Total Mix or is this problem Cubase?
Any advice would be helpful.
Regards, Acul
