Topic: Is RME my next solution?
I am investigating if the RME Fireface UFX might be a good solution for me.
At this moment I work as follow:
I have a Tascam DM4800 with optional firewire card. This means that this digital mixer is actually my soundcard. I own a lot of hardware synths. Via the Tascam I can monitor these hardware synths within Cubase. Since I want to use VST FX on those channels I can not use direct monitoring so I always have latency issues. Within Cubase I use VST instruments as well which I mix with my hardware synths (the channels I monitor). To get things in synch I manually adjust the latency. Via Internet I learned that I have to compensate the total amount of my input and output latency from the soundcard to get things in synch.
For the record I do not record anything in Cubase. Instead I only record the end-mix in another audio program.
At this moment I have the following problems:
-    The latency I must compensate is not the total amount of my input and output latency. This means I must use my ears and trial and error to
             get it as good as I can hear. It also isn’t very stable.
-    I also think that the AD converters of the Tascam are not very good. Often hardware synths sound worse then VSTI which is kind of strange.
RME has of course a reputation when it concerns latency. But if I continuo to work as described above will the UFX solve all my problems?
Re: Is RME my next solution?
Hi Johan,
Even though the Tascam D4800 is a nice sounding mixer it's Firewire performance was so so. The UFX or any other of the RME devices will higher performance lower latency drivers across the board.
How many analog channels do you need for these dedicated hardware analog synths?
The UFX only has 12 analog inputs and outputs. The rest are ADAT and AES. You would need AD/DA added to the UFX or hook up the Tascam into the ADAT channels for more than 12.
If you are using Cubase SX 4 or higher then I'm assuming your using "External Instruments" for you hardware synths?
If you add a 2nd AD/DA converter or your Tascam to the ADAT/AES I/O then you do have potential for a slight timing difference the UFX AD/DA and the external AD/DA. This is not a issue unless you are sending the same source to both AD/DA at the same time.
If the sound source are independent then the slight time difference will not make a difference.
If for some reason your computer is too slow or your project is too large to deal with very low latency settings then you can easily configure RME's Total Mix to monitor your hardware synths instead of monitoring though Cubase.
The Tascam is a nice sounding so even though the UFX does sound better over all to the ears as well as on paper it will not be a night and day difference. The biggest things you will notice will be the more reliable drivers and if your getting ride of the Tascam the huge amount of studio space you have now. smile
The UFX stand alone routing and recording features will be great when you just want to jam when you don't have the computer up or if you want to record something on location or just jamming.
Thanks Chris
Chris Ludwig
North East USA Sales | Synthax/RME
www.facebook.com/RMEAmericas
Twitter @RMEAmericas
Hi Chris,
Thanks for your reply.
Well I guess the quality of the UFX AD converters must be good. On the Internet people claim it can compete with most high end solutions. Also 12 analog inputs is enough for me.
My biggest concern is getting the analog input channels from the UFX within Cubase in synch with VST instruments. The overall latency is not a problem for me. Since I use lots off VST FX on most channels I presume I must setup a high sample buffer to avoid clicks.
But if I for example setup the sample buffer to 512 the input latency is 12.063 and the output latency is 20.068.
Is it true that if I manually adjust the latency on the midi channels (I use a MOTU midi express 128 to control my hardware synths) with the total of the input and output latency (12.063 + 20.068 = 32.131) it will be in synch with VSTI? So I adjust the latency of the midi channels to get the UFX analog inputs, which I monitor with FX, in synch with other audio within Cubase.
People on Internet say that this is the way to calculate latency compensation. Unfortunately this does not work with the Tascam.
B.t.w. I do not use “external instruments” in Cubase. I tried this once but I got the same result as with a normal midi channel.
Hi Johan,
Your live MIDI should not be noticeably out of Sync with VSTi even at higher buffer settings.
MIDI is not effected by the ASIO buffer size.
The latency would only be effecting the Monitoring of the External Keyboards signal though Cubase.
If your system is too slow to operate at lower buffer settings i.e., 256 (6ms) or lower then you can setup Total Mix FX to monitor your external Keyboards and avoid the added latency of passing though both the ASIO driver and Cubase.
This of course would mean not being able to use VST effects on your HW Keyboards until you have recorded them in as audio into Cubase.
The RME driver is a very efficient even on slower systems so you may be able to keep the buffer setting lower on bigger projects with out clicks. The faster your system the lower you can keep your buffer settings. Some drivers seem to have a brick wall no matter how fast your system is and juts won't work well at the lowest settings.
I've only noticed MIDI built in delay when trying to trigger the same sound in both a VSTi and an external keyboard. Snare drums or high hats can be very noticeable with 16 beats or higher. This was an issue even back in the non computer days between different brand keyboards all having slight difference in the MIDI delay and timing.
If you want to use VST FX on your HW Keyboards then the most effective way to do this is with Cubase's External Instrument feature.
Thanks Chris
Chris Ludwig
5 (edited by vinark 2011-09-26 16:53:54)
I do use external instruments exactly for this in cubase and it works here for the latency compensation. Remember that some old synths are really slow over midi, sometimes in the 10 to 20ms range. But even that is easy to compensate with external instruments in it's setup and will from then on always be in time, whatever latency you set for the RME driver. Even so I can use my RME hardware even with 32 samples buffer which is almost neglectable.
I have somewhat older rme converters and even those sound great!
About older synths sounding worse then vsti's, that is absolutely possible, especialy the last years some great vsti's came out and the only synth I have that I have that isn't equalled by a vsti is my yamaha VL1m. But I don't have any analogue monsters sad unfortunately.
Hi Chris,
Thank again however I still do not really get it.
Here is a very simple example:
- I have one VSTI (for example Waldorf attack). I control this VSTI via a midi channel. Cubase automatically also creates an audio channel. I can of course add FX (for example CSR hall) to this audio channel. Very basic I think.
- Now I want to add the sound of a Hardware synth. For this I also create an audio channel. This channel is setup for monitoring the hardware synth. For this audio channel I also want to use VST FX. This makes direct monitoring not an option.
Now because I can not play anything in real time I also create a midi channel to play the notes. So via my midi interface Cubase controles the hardware synth.
The problem is both channels are not in synch. To get this in synch the only way I figured out is to use the track delay in Cubase. The problem is that I have to use my ears to get it in synch. When I enter the total of the input and output latency of my Tascam soundcard it is still out of synch. And it is also not very stable.
Maybe this way of working sounds stupid but this gives me the great advantage that I can control everything without have to record anything (except the end-mix of course).
Will this be stable and can the latency be calculated with the UFX. Another trick or option is of course very welcome.
Hi Johan,
Monitoring Though Cubase the way you do just a more convoluted method of what Cubase's External Instrument does.
As Vinark mentions when using you can do any extra latency adjust inside the external instrument options instead of on a per track basis. Using the External Instruments is very handy when using Hardware Keyboards with Multiple analog outs.
I do not know how big or how fast your computer system is but the average PC that is 4 or 5 years old should be able to run most projects at 256 buffer. On current machines 128 buffer tends to be the average. Some fo the 6 and core systems can easily run a decent sized project at under 128 buffer.
On the UFX using Cubase5/6 under win 7 64  256 = input-6.417ms/output-7.347ms. At 128 = input-3.515ms/output-4.444ms. At 64 = input-2.063ms/output-2.993ms
If you had to operate at 512 then here are the numbers. 512 = input-12.222ms/output-13.152ms
Thanks Chris
Chris Ludwig
Yesterday I tried the external instrument option in Cubase. I got the exact same latency problem as with “normal” monitoring. Although I release it is a handy option for synths with multiple outs.
I also tried different sample buffer settings. The results are all the same. I always have to total the amount of input and output latency of my soundcard and then there is still a latency gap around 12 ms.
I don’t think it has anything to do with my midi interface. I also have a moog LP which has its own USB midi driver. This Moog runs perfectly in synch with my other hardware synths that go via the midi interface. I also don’t think my hardware synths have midi latency’s in the 10 till 20 ms range since they are in synch with each other.
I still think it has something to do with the Tascam. If I route a signal directly to the stereo outs of my Tascam board (so the signal does not come in cubase at all) there is also a 12 MS latency difference with the cubase metronome. My system should be gas enough (I7 quadcore)
I think I go the shop and try to create a similar setup with the UFX and hopefully I become a new happy RME user.
One question to Vinark: how do you know how much ms you must compensate in the external instrument set-up?
I simply recorded a percussive sound and looked in the audio editor how many ms late it was.
Also some synths have more midi latency when you play more notes.
If the tascam is not reporting it's latency correctly to cubase, cubase can not correctly compensate. A lot of the lesser audio interfaces have hidden safety buffers, which are not reported to cubase.
BTW cubase can ofcourse only compensate for the latency in playback. Not during live playing or recording.
Hope you will like your RME if you go that route, I do....
Hi Johan,
Yes that is very odd info about the 12 ms latency even when monitoring directly in the Tascam.
Do you have any effects active on the mixer? Perhaps there is a effect that is adding extra latency into the signal.
I know there are some VST effects that do this in Cubase that make them unusable for tracking.
This odd 12 ms latency that is happening in the Tascam Mixer will not happen on the RME.
Thanks Chris
Chris Ludwig
