Topic: Realtime control Fader across presets
Hi, I am in a bit of a bind.  I need to be able to have constant control over the 1/2 and 3/4 output faders while changing presets.  Is this possible?  To better explain:
I essentially use my Fireface 800's presets to tell Ableton 8 what instrument is coming into input 1/2 for a looping setup.  Throughout my set (this is for Live performance) I may change the master volume when my loops stack and become too loud.  The issue is when I reduce the volume in preset #1 , and then switch presets to #2, I generally get blasted with a large increase of volume because preset #2's fader was last at Unity, and didn't change with preset #1's fader.  Is there anyway to link the faders to prevent this?
Re: Realtime control Fader across presets
Sorry, no way to change that. Don't know your setup, but volume control independent of the presets could be done via the headphone output.
Bummer,
Thanks for the quick reply
