Topic: Loopback function on ufx
Does the loopback functions signal from total mix to logic or daw,pass thru d/a and actually records the d/a from the ufx to logic?
Re: Loopback function on ufx
No. All digital.
How can I get the d/a conversion back to daw with just the ufx?
With audio cables of course :-) .
But there is no reason to prefer that above digital loopback, the rme converters and analogue circuitry have no mystical properties. You will only be adding noise and distortion (ok very little of that, cause rme gear is very good cool )
out  where to in where?
Every analogue output to input you want. For example 7/8out to 7/8in, or 3/7 to 2/6 why not get wild? Where/why do you see a problem here?
Thanks ,i just wasn,t sure and haven,t read the manual yet
