Topic: babyface - totalmix latency questions
hi folks,
loving the babyface so far.
am i right in thinking that when using direct monitoring thru totalmix, the signal is only going straight in and out of the babyface unit (and thru the totalmix mixer), and not down the USB cable to the pc and back? ie the usb cable length has no effect on latency (however small)?
what is the actual latency of doing this? i know it is referred to as zero-latency, but presumably there is a certain number of samples latency?
and more specifically to my actual setup - how about when using an ADI-8 DS into and out of the babyface via toslink? total latency is then totalmix latency + ADI ADDA latency? how much is the ADI-8 DS roundtrip latency?
i appreciate these are going to be very tiny figures, but in the interests of complete understanding of the setup... :-)
gary.
Re: babyface - totalmix latency questions
The USB cable will cause no noticeable (and practically not even any measurable) latency, regardless of length. Converter latency is about 1 ms each way or so.
hi daniel,
thanks for the info.
how about if you're using an active usb extension cable coupled to a normal usb cable? anything added in that scenario?
so are you saying the signal is doing a round trip down the usb cable during direct monitoring? and what is the totalmix mixer latency? a handful of samples?
gary.
Yes. But if you record and playback the signal or play it through the software audio engine it travels over the USB cable and back.
Yes. AD/DA latency is around 40 + 30 samples.
best regards
Knut
Yes. If you record and playback the signal or play it through the software audio engine it travels over the USB cable and back.
perhaps i didn't describe that very well. obviously if you're monitoring without direct monitoring on in (for example) cubase, the signal is going down the usb cable and thru cubase's mixer and back. i'm talking about monitoring with direct monitoring on and not thru cubase, ie zero-latency. are you saying the signal is still going to the pc and back in this scenario? i understood that the totalmix mixer resided in the babyface itself?
gary.
Of course not. ASIO Direct Monitoring = TotalMix monitoring = direct hardware monitoring inside the box.
Yes. As MC wrote with hardware monitoring the audible (!) signal does not travel through the USB cable and back. It goes from the input to the TotalMix hardware chip to the output.
best regrads
Knut
great- thanks. that's what i wanted to verify.
actually - how about the active usb extension question? will using a 5m active extension chained to a 3m usb cable add latency in a non-direct monitoring situation? i've seen a few user reports suggesting possible problems with latency and these repeater cables. when i tried it it felt like there was an added latency but it could have been my imagination...
gary
10
That's complete nonsense. And easily verified by a loopback recording with and without the additional cable.
