Topic: FF800 Pre-Amp Channels 7-10 Static, Pops, Sizzle with Condenser Mics
My FF800 has been working fine for 2.5 years.
I got a new condenser mics (AMT 350s) for my room drum mics.
I noticed very extreme popping sizzling, crackling noise where LED lights hitting towards unity.
This was only on one channel (7, I think).
I unplugged the condenser and put it in 8.
The problem then appeared in 8.
I unplugged my overheads in 9, the problem happened there.  When I plugged back the condenser I had in 9, the problem continued.
I then turned off phantom power and plugged in a dynamic (sm58).  No noise.
I then put the AMT 350 mic in my separate mixer -- clean, no noise whatsoever.
I checked cables, turned off my dac (logic), and rebooted, used a completely different condenser and preamps 7-9 are still unusable -- sounds like frying bacon.
Is my RME preamp chip blown?
If so, what caused it and how can I 1) repair it; and 2) avoid it in the future?
Re: FF800 Pre-Amp Channels 7-10 Static, Pops, Sizzle with Condenser Mics
Not the preamp chip (dynamic mic works), but the phanton power supply or the protection circuit is broken and needs repair. And yes, pluggin/unplugging mics while phantom is on is dangerous.
OK, thanks, I sent Jeff a note at Synthax, hopefully this can be fixed easily.
