1 (edited by romik 2011-10-18 12:59:05)
Topic: Clipping audio
Something recently caused audio to clip within audio applications, if I import audio into Pro Tools (commercial tracks) audio is already clipping and distorting. Increasing gain in plug ins also causes distortion although tried various limiters on main buss, so audio is distorting pre-limiter stage. I have installed driver for Fireface 400 (updated one) but problem hasn't gone away. No settings in DAWs have been altered. System prefs are same as before. All I noticed is that on Fireface Mixer window when opened misalignment of green digits lower right corner and right top. Hopefully you can see what I am on about.
Basically, when I impmort any audio file into a DAW that previously played back correctly now plays back louder, higher readings on meters.
Please advise.
Thank you,
Roman
http://i55.tinypic.com/dmw65c.png
http://i52.tinypic.com/16icutl.png
Re: Clipping audio
Do you have any trouble with other apps, such as iTunes?
