Topic: Hdsp 9652 input levels intermittently spiking
I will try to make this concise and thanks for any input
RME products:
HDSP 9652 AEBX expansion boards( 3 total) 16 channels in 8 channels out
latest driver update ver291 ( has been working flawlessly since it's release in 2005 )
My PC ( has never been on the internet)
AMD Athlon (B) XP 3200+ 2.20GHz
ASUS A7N8V-LA MOBO
nForce2-IGP chipset
2 gigs ram
Cubase SX3
After a couple of years of having a very stable system, I am now having this problem.
When I boot my system, sometimes it is fine, other times the inputs are spiking on all 16 inputs,creating much noise and crackling.
If I shut down and reboot, it sometimes solves this, and other times not.When it boots up , it may run solid for hours, at other times it will run solid for a couple hours and then the spiking starts back. Strangely enough, I can still playback from Cubase and it sounds fine even when all the inputs are going nuts.
This happens even when my mixer is shut down and I am sending no signal.
Any clues on what to check ? I havn't updated my driver because the system was working very well.
If I do update, can I go to the newest driver, or do I have to update chronologically from my most recent driver, which is a couple of years old.
