Topic: EQ for just listening?
Hi all
Been recording so far without using babyface's EQs. But now i'd need to put EQ to input signal but just for monitoring, so my DAW would record unEQed signal. I got the impression that this would be the normal behaviour of babyface, but nonetheless my DAW (sonar) recorded the EQ as well is there a way to correct this? Of course i can EQ the DAW output, but that applies to all tracks then, and is less than ideal solution.
cheers
Pekko
