Topic: Using 2 Fireface 800 and connectivity problems
Hi everyone,
If I post here, it's because I've exhausted all my other options. I have recently purchased a second Fireface 800 (I've had my first one for over 4 years) and am looking at using them both at the same time in order to record drum sessions (I like to use a lot of mikes so I need roughly 15-16 simultaneous channels).
I've read the manual, read all the related posts here and watched the Youtube video tutorials and have tried all possible configurations, yet my problem remains. Here's what's happening:
My two Firefaces have the latest firmeware update (2.77) and my drivers have also been updated (3.0.59 or something like that) and both can be used individually without any issues.
All the drivers and channels appear and are available in my DAW (I work with Sonar 8.5 Producer and Sonar X1 Producer Expanded), yet, when I use my main soundcard (the one defined as "internal" (master)) as the main out, the audio engine is not producing any sound at all (and the peak meters remain dead in the DAW).
But when I switch the main outs to my slave soundcard (I've used word clocks, adat, you name it to synch them), then I have sound and everything works perfectly, except of course that when I select the INs of my master soundcard, I cannot record any sound at all.
And yet, I can see in Totalmix that there is sound coming in, but for a reason I cannot understand, it just won't go from the Totalmix driver to the DAW.
This is a very strange issue and I haven't found any threads mentioning such a problem, so I don't know if someone has experienced something similar and can help me, but I sure hope so.
Please note that I record in 192khz so using ADAT cables with one sound card as a standalone is not an option as ADAT is limited to 48khz. Anyway, I have tried this configuration during my tests, and I had jittering issues at 48khz, while I never had any such isses for 4 years working at 192khz.
Extra info: I have 2 Firewire 400 and 2 Firewire 800 ports on my computer, and I have the cables, and I've tried the various combinations.
So, that's about it! Let me know if you need any extra info, and I'm looking forward to reading your replies!
Cheers!
