Topic: Wordclock and Adat clocking together?
I have a Raydat card with the optional Bnc/Wordclock card.  Now i have a few questions on how to set my clocking between all my units.
My gear is:
Apogee Rosetta 800 (Bnc/Wordclock in and out, also adat in and out)
Presonus Digimax Lt (Bnc/Wordclock in and out, adat out)
Sm Pro 8 channel preaps with adat card (Bnc/wordclock in and adat out)
Now my the Bnc/Wordclock card on my Raydat only has 2 outs so i can not connect all 3 as i heard daisy chaning wordclocks is bad.
Can i run the Apogee 800 clock via adat and then wordclock for the other two units?
Or is there a better way to set this up?
Any advice would be great.
Re: Wordclock and Adat clocking together?
Yes rosetta on adat is possible and just as good as wordclock. What device do you use/want as master. I would choose your most important or best sounding device as master.
Rosetta is my most important.  So then I would run the Rosetta as my master via adat to my rme and run the two bnc cables from the Rme card to my other units?
Yes :-) . Easy as that.
