Topic: babyface without breakout?
hi there everyone
i'm just trialling a babyface for my laptop because i am trying to save as much weight as possible. so far i'm very impressed, sound quality is excellent and i can get 3ms latency with no dropouts at all. and it powers just fine off 1 usb port, so happy days are here.
but i just wanted to know a couple of things, and i figured this forum would be the best place to ask. ideally i'd want to leave the breakout cable at home, and so it seems fine to run a standard stereo out to 2xRCA from the headphone port - i assume the sound quality there is the same as that on the 'normal' XLR outs is it? since i plug into RCAs anyway having balanced does nothing. obviously this means i don't have separate headphone out but i don't need that really.
also, i have a microphone with a standard 1/4" plug, it is a dynamic microphone with 5k impedance. if i plug it in to the instrument in, and turn the gain up to about 48 or so, it sounds ok, but is this actually a good idea? or am i bypassing something that i would be getting using XLR cable into the breakout cable? i don't really "get" the impedance thing although i've looked into it a bit - the babyface has 2k impedance it says according to spec...
thanks in advance for any advice, sorry if i asked obvious questions smile
cheers,
S
Re: babyface without breakout?
sorry to bump, but no-one can answer this? i have it on trial only for 1 week (and it's still sounding great) so if i know this i'll definitely keep it smile
thanks!
S
thanks!
S
It would be helpful to know the brand and model of the microphone...
If it sounds ok to you, it will be ok... Not ideal maybe, but not harmful.
thanks for the responses smile
so it's using the same DACs for the headphones as for the main outs too?
romnac, the mic is an akai adm-40 - quite old school but it still works smile
