Topic: Hammerfall DSP : artifacts when playing 12 or more channels
Is there a bandwidth problem with the Hammerfall DSP?
- I tried to use up to 16 channels
- Routed the first 8 virtual outputs (Analog 1-8) to the first 8 physical outputs (Analog 1-8).
- Routed the next 8 virtual outputs (ADAT 1-8) to the first 8 physical outputs (Analog 1-8).
TEST 1 : 9 channels ( 8 analog + 1 ADAT) : everything normal
TEST 2 : 12 channels ( 8 analog + 4 ADAT) : output test normal, artifacts during measurement every now and then
TEST 3 : 16 channels ( 8 analog + 8 ADAT) : sound played back at what seemed to be a lower sample rate (the sound was slower than normal), severe aliasing-like artifacts
using driver 3.24
