Topic: Babyface dim function
Since I couldn't find answer anywhere I would like to ask how can I change the output to Speakers B using only the Babyface? I've read somewhere it can be done, but the the actual way of doing it was nowhere to be found.
Also, I don't know if it was already reported but when I select output on Babyface and press the rotary button to activate dim and then I change to input via select, the two LEDs indicate that the pressing of the button, even though with output selected, changed the input selection of channel too. It's a minor glitch but I wonder if it could be addressed with firmware update or not. Thanks.
