Topic: UFX - Hardware Problem
The tip of a phone plug came loose from the sleeve and is stuck in a headphone outlet of my UFX.
Is there a way for me to get this out without taking the unit apart?
UFX+ x2 ; Babyface Pro x2; UFX Original;  Windows 10 64 bit ; Intel core i9 9900KS CPU; 64 Gig DDR4
Re: UFX - Hardware Problem
Got out without opening the unit!
I put a small amount of epoxy on the part extending from the sleeve of the phone plug ( a very little amount of epoxy so that it would not run out into the UFX) and pushed the plug back into the headphone jack up against the broken off tip - let it set over night and pulled the whole thing out this morning.
