Topic: UFX: How far can you go with the DSP / Midimapping questions
Hello RME et all,
A couple of questions (and pardon me as I'm a little confused on some of the info I've been reading):
1) Is there a way to utilize the ufx's dsp to independently process 88.2 / 96Khz sample rates while still working with a laptop (ableton)? What sample rates / buffer settings are possible in stand alone? I'm wondering if it can somehow take the work load off of a plug-in heavy live laptop set up (which utilize customized plug-ins that the UFX doesn't have, in case you suggest to have the ufx take more of the effects load)
2) In Totalmix FX is there a way to set up 2 (or 3 or 4) different routing situations and have each routing template where I could switch between them using a midi controller (in stand alone as well)?
Thanks for reading,
Am
Re: UFX: How far can you go with the DSP / Midimapping questions
Anyone?
