Topic: Multiface I converter chip upgrade
I was thinking of changing the old AD/DA converter chips to a newer ones in MFI...
Has anybody done that? Is it even possible?
IIRC it uses AK4528 chips and AKM is probably doing some updater version by now.
Re: Multiface I converter chip upgrade
Seriously? No answers?
It shouldn't be too tricky to upgrade them...
Sorry, but you don't really expect a readymade solution here, do you...? HeadScratch
I'd suggest to do some research of your own initially - i.e. whether or not there is such a thing as a pin-compatible successor to this AKM codec. If not, that's the end of the idea anyhow. If yes, go ahead and replace it - at your own risk...
:-O
