Topic: New UCX has high pitched noise
I have just recently bought the RME UCX. When I got the device, I noticed that there was a high pitched noise coming out of the headphone output. The noise would change when I was moving the front knob of the unit.
At first I thought that there was a ground loop issue, but then I disconnected the device from the computer completely running it only with the power adapter. The noise was still there. So I returned the unit to DV247 , where I bought it from. They also checked the unit and confirmed the problem I was having. So my unit was replaced with a new one.
However, I found out that the new unit also exhibits the same problem. And still the problem exists even if I have the unit running in standalone mode without a computer connected at all.
is there any way to overcome this problem or have I tried units from a faulty batch?
If this is the case I will have to return the unit as soon as possible for replacement.
Thank you in advance,
Jade Chang
