Topic: No out in th digicheck on Macbook pro
Hi there.
Im trying to get the digicheck to work.
And the only thing that i get working is the in signal and not the out. Cant even find what channels to select for the outsignal. What am i missing and how do i get it to work?
Working of the babyface.
Re: No out in th digicheck on Macbook pro
Use the loopback feauture of the mixer to send signal to inputs for measuring. Output measurement will be added to the OSX version in an update.
Ahh ok. Ill wait for the update then.
Thank you. big_smile
4 (edited by damiafix 2011-12-03 18:17:42)
I've the same problem with Digicheck 0.645 on Mac, especially for the Spectral Analyzer, it's impossible to select the output level, only the input.
Look here:
http://img231.imageshack.us/img231/9744/schermata20111203a16582.th.png
On my mac, it's possible to select the output/playback/input level only for the "bar meter"
http://img36.imageshack.us/img36/4144/levell.th.png
and the "global meter"
http://img805.imageshack.us/img805/3306/schermata20111203a17580.th.png
it's normal?
All the best.
D.
Hi Daniel Fuchs
I'm using Digicheck long time. on pc
since 1/2 year i'm using a mac
like all other users that work with mac, i'm wondering why te playback function not work for mac.
we are waiting so long time for a update of "DIGICheck 0.645"
i'm checking every time for a update and I am disappointed again and again.
i cant use this loop trick because i need the 2outpus and 2 inputs! its not a good solution
so, i thing i write for all mac/rme users:
Why this playback funktion not work on mac?
can we expect a new version or not?
it gives a not-official version?
please make this work !!
im loving the rme products smile
but this playback problem on digicheck making me not happy with your product.
please explain why its not work and how long we have to wait.
many thanks
j
The playback feature had to be cancelled (which I already announced in this thread:
http://www.rme-audio.de/forum/viewtopic.php?id=8712
Post 7). While trying to implement it we had to find out that it is much more complicated than expected. One way to do it would require firmware updates but still be limited to a few fixed channels for playback monitoring.
This feature wish might come back at a later date with other fresh ideas on how to do it.
hmm, I was going to buy UCX only because I can't use Digicheck with my HDSP PCI on my "Mac" but reading this I kind of don't want to do it anymore… btw. does Digicheck works with UCX?
It works.
best regards
Knut
I dont seem to have an option to monitor the `output` of my UCX in Digicheck
Is this possible,, worked on XP windows
im running
osx 10.8.2 - latest digicheck - latest driver and firmware for UCX
thanks
The OSX version does not support this. Use loopback and monitor at an input.
11 (edited by jrobot1 2013-01-07 11:57:54)
Hi Daniel,, thanks for the info...
Under windows i found the monitoring of the output in Digicheck invaluable for working on a mix, truly a top tool!!
I was surprised this seems to be an issue with core audio - and from RME support posts seem that it is something very tricky to get sorted!
Thanks for the how to,, im not familiar with the looback feature - is there a how to anywhere - or could someone kindly point me in the right direction.
All i would like to do at the moment is monitor the main output channels in digicheck - say - Analog outs 1-2.
cheers and thanks,,,, Rme always great support!!
Loopback is explained in the manual ("Recording a subgroup).
ok cool thanks Daniel,, i`ll check that out...
