Topic: Problem with raydat on fedora linux
I've got a strange problem with raydat on latest fedora 64bit.
At some time the card stops playing, and all settings in amixer are messed up, like reported.
I have to reset my pc to let the card play again.
If I remove and then reload hdspm module the pc hangs.
my box is a new core i7 sandy bridge:
As you see below system frequency is messed (24414 Hz)
input status is very strange.
Firmware is version 12
asus p8z68 v pro gen3
16 GB RAM corsair
intel core i7 2700K
Thanks for your help.
Simple mixer control 'ADAT1 Frequency',0
Capabilities: enum
Items: 'No Lock' '32 kHz' '44.1 kHz' '48 kHz' '64 kHz' '88.2 kHz' '96 kHz' '128 kHz' '176.4 kHz' '192 kHz'
Item0: '192 kHz'
Simple mixer control 'ADAT1 SyncCheck',0
Capabilities: enum
Items: 'No Lock' 'Lock' 'Sync' 'N/A'
Item0: 'Sync'
Simple mixer control 'ADAT2 Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'ADAT2 SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'ADAT3 Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'ADAT3 SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'ADAT4 Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'ADAT4 SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'AES Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'AES SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'Chn',1
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - 64
Mono: 64 [100%]
Simple mixer control 'Clock Mode',0
Capabilities: enum
Items: 'Master' 'AutoSync'
Item0: 'Master'
Simple mixer control 'Internal Clock',0
Capabilities: enum
Items: '32 kHz' '44.1 kHz' '48 kHz' '64 kHz' '88.2 kHz' '96 kHz' '128 kHz' '176.4 kHz' '192 kHz'
Item0: '44.1 kHz'
Simple mixer control 'Pref Sync Ref',0
Capabilities: enum
Items: 'Word Clock' 'ADAT 1' 'ADAT 2' 'ADAT 3' 'ADAT 4' 'AES' 'SPDIF' 'Sync In'
Item0: 'Word Clock'
Simple mixer control 'SPDIF Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'SPDIF SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'SYNC IN Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'SYNC IN SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'System Sample Rate',0
Limits: 27000 - 207000
Mono: 24415 [-1%]
Simple mixer control 'TCO Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'TCO SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Simple mixer control 'WC Frequency',0
Capabilities: enum
Item0: '192 kHz'
Simple mixer control 'WC SyncCheck',0
Capabilities: enum
Item0: 'Sync'
Output of lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 05)
00:1a.0 USB Controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 82801 PCI Bridge (rev b5)
00:1d.0 USB Controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Z68 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
03:00.0 USB Controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
04:00.0 Multimedia audio controller: Xilinx Corporation RME Hammerfall DSP MADI (rev d3)
05:00.0 USB Controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
06:00.0 PCI bridge: ASMedia Technology Inc. Device 1080 (rev 01)
output of lscpu:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 42
Stepping: 7
CPU MHz: 3511.518
BogoMIPS: 7023.03
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 8192K
NUMA node0 CPU(s): 0-7
output of /proc/asound/card0/hdspm
STATUS1: 0xffffffff
STATUS2: 0xffffffff
STATUS3: 0xffffffff
*** CLOCK MODE
Clock mode : master
System frequency: 24414 Hz
*** INPUT STATUS
s1_input 0: Lock 1, Sync 1, Freq Sync In
s1_input 1: Lock 1, Sync 1, Freq Sync In
s1_input 2: Lock 1, Sync 1, Freq Sync In
s1_input 3: Lock 1, Sync 1, Freq Sync In
s1_input 4: Lock 1, Sync 1, Freq Sync In
s1_input 5: Lock 1, Sync 1, Freq Sync In
s1_input 6: Lock 1, Sync 1, Freq Sync In
s1_input 7: Lock 1, Sync 1, Freq Sync In
WC input: Lock 1, Sync 1, Freq Sync In
TCO input: Lock 1, Sync 1, Freq Sync In
SYNC IN: Lock 1, Sync 1, Freq Sync In
output of /proc/asound/card0/debug
0x00000000: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000010: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000020: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000030: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000040: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000050: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000060: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000070: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000080: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x00000090: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000A0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000C0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000E0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
0x000000F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
