Topic: Problems with inputs 9 & 10
Hi everyone.
I can't seem to get inputs 9 and 10 to pass signal to protools.  I'm getting healthy levels in totalmix, but nothing on my record-armed tracks.  Inputs are set correct in PT.  Fireface has no Bandwidth limit engaged.  Please help!
Thanks,
Phil
Re: Problems with inputs 9 & 10
If you see the signal in TM, then it would seem the problem is not in the FF settings. Double check the IO setup in PT (Set Default).
That did it!  Thanks!  Sorry for the noob question.
