Topic: Correct settings for ITU1770/EBU R128 dialogues?
Just checking really.
In the help files, it states with K-system that the caution level is set to 4dB, yet on opening here it was set to -10dB.
There is no mention of the correct warning levels - what should this ideally be set to? It opens up at -3dB
This is on version 5.43 on PC.
Is there a preset file I can download with the correct or recommended default settings already made?
Many thanks and my apologies for ignorance!
Re: Correct settings for ITU1770/EBU R128 dialogues?
There are no 'correct' warning levels for the left level meters. Set them as you like.
