Topic: OctaMic II max gain?
I have compared the mic preamps in my FF UC with my OctaMic II. Using two AKG 414s, and listening to a quiet sound source, I found that 60dB gain in the OctaMic corresponds to 50dB gain in the UC.
I switch the cables, tried different channels in the OctaMic but the difference was the same.
The OctaMic is connected via ADAT at 41,1kHz. As an extra check I also connected the OctaMic with a TRS-cable from line out to line-in in the UC. The level stayed the same (I'm using +4dB reference level on both the UC and the OctaMic).
So, who is telling the truth? Is max gain in the OctaMic really 50 dB or is max gain in the UC 70 dB? Or am I missing something? That would not be the first time…
Stefan
