Topic: Loopback question
Hello!  I am loving my babyface!  I do have a question about recording reverb and/ or delay.  It seems as the babyface only has two inputs, the loopback only appears on the main output and not the phones.  While I understand I cannot "loop back" to an input that doesn't exist, I want to know if I can record verb/ delay without turning off the monitor amp (or unplugging it).
I usually track late at night with headphones, but I mix and such with monitors as much as I can albeit at a low volume because the wife and kid are sleeping then.
With loopback engaged on output 1/2 (Main with old names) sonar does not see signal on the appropriate input channel unless the main fader is up.
Is there a workaround or any way to assign via an AS output channel or anything, or do I just turn the amp off?  I have tried to assign the output of the channel I am recording on to ADAT 1 output, but that loops back to the digital inputs correct?
Thanks very much!
-eric
Re: Loopback question
I think I figured it out, at least partially.  I can assign that corresponding ADAT number as the sonar track input, engage loopback on the same ADAT hardware output, and it does print the effect.
Is there an easier way?
-eric
