1 (edited by scoring4film 2012-06-23 00:50:31)
Topic: HSDPe AIO driver install = Blue Screen in Win7
I read and followed the instructions in the "Installation of RME Audio Interfaces under Windows 7" sticky...
http://www.rme-audio.de/forum/viewtopic.php?id=7348
The card is detected, driver installs fine, but Win7 goes blue screen on reboot after the driver install.
What should I try next?
Info that might be relevant...
-The HDSPe AIO is installed in the second of 2 PCIe slots on an Asus P8Z68-V Pro (GEN3)
-A UAD2 card is installed the the first PCIe slot
-There is also an RME HDSP 9632 PCI card in one of the lower PCI slots
THANKS!
Re: HSDPe AIO driver install = Blue Screen in Win7
You could try to change your Windows Firewire driver to the "(legacy)" one via Device-Manager.
3 (edited by scoring4film 2012-06-24 02:22:01)
Thanks for the suggestion Timur.
I swapped the HSDPe AIO into the first PCIe slot and it came to life.  Existing drivers picked it up.  Now the UAD2 card won't work in slot #2.  Maybe an IRQ issue with that slot.
I bought the AIO to replace my 9632 PCI card, assuming I'd get a bit of extra ASIO performance (because I found out the PCI slot on my board is bridged, not native).
Surprise, surprise, after much testing, I see little to no ASIO perf. improvement with the new HSDPe AIO card.  I had assumed the Asus PCI-to-PCIe bridge chip was eating up ASIO.  I guess I was wrong.  Bridge seems to work very well.
Anybody want to buy a slightly used HDSPe AIO?  :-D
