Topic: FireFace UFX and a Noob....
I have the FireFace UFX hooked up to windows via USB. I also have the Eleven Rack hooked into my PC via USB for the software interface I use in Pro Tools 10 to configure the 11r. The Eleven Rack is going to my UFX via AES/EBU and my UFX back to the Eleven Rack via AES/EBU.
I have a pretty beefy Windows 7 sp1 set up with an i7 at 3.6ghz and 12 cores with 32 gigs of ram.
Ok, here is the problem. Whenever I plug a line or mic into an input - let's say Analog 9, either 48v or inst, I get a signal back out to my headphones and monitors A and B. However, none of my DAW software applications will pick up the signal. For example, I do the following:
On the UFX input - Analog 9, I plug a 1/4 guitar cable in and plug that cable into my guitar. Then in TotalMix FX, in the hardware inputs, I Choose Mic 9 and select Inst. Then in TotalMix FX, in the Hardware Ouputs I select Analog 7/8 and I hit a chord on the guitar. I hear the guitar coming through my headphones on Phones 1 and Two, I also hear the Guitar through my Monitors. My main monitors are assigned to
AN 3/4 via the Main Out and my secondary Monitors are assigned to AN 5/6. However, if I open up Pro Tools 10 and select a track and assign 7/8 as the input and the proper output and arm the track, I get no signal in Pro Tools. I am kind of new to Pro Tools too. I am very familiar with Cubase. I open up Cuase 6.5, set up my connections for my Input Bus to Stereo - Left --> UFX AN 7 and Right --> UFX AN 8 input. Then I create a track in Cubase arm it and assign the bus I just created, ensuring again that the Hardware Outputs in TotalMix are Analog 7/8 and that my input bus is set up correctly, I still get no signal.
If, however, I plug my guitar or mic into the 11r and set the Hardware outs to AES and do the same in either Pro Tools or Cubase - everything works great. I obviously do not want to use my 11r has my main audio interface and miss all of the great things about the UFX. What can I do? What am I missing or doing wrong? I have read the manual , well most of it, watched YouTube videos etc but nothing seems to address my problem.
Thanks in advance for any help.
