Topic: Best clock source options for RayDAT into ADI-8 DS converters?
Hello.
I just got delivery of my new DAW, and have found there is no Word Clock option - I used WC for years with my HDSPe 9652 and I am at a dead loss to know what the best clock source option is to prevent clicking.
Currently, it is set to "sync in" which prevents clicking but constantly triggers a "the sample rate has changed" nag screen every time I open a project.
What I would ideally like to get is a setup where the Nuendo sample rate changes when I press a button on the ADI-8, which is how it used to work with WordClock.
OS = Windows 7 x64
Host - Nuendo 5.5.5 64-bit & 32-bit versions both.
Re: Best clock source options for RayDAT into ADI-8 DS converters?
It will work the same way if the card syncs to incoming ADAT. What exactly is the "Sync in" setting you are referring to?
It's the "Clock Source" setting in the Hammerfall DSP settings window.
Please excuse ignorance - I am so used to WC controlling this (daughterboard for RayDAT ordered)
I have the same issue...could you fix it?
Mac OS X - Intel I7 - 24GB Ram - Digi 003 - Presonus Studiolive 16.4.2 - Neve 1272
HeadScratch
