Topic: Firefac UFX ADAT Latency
I've got a Digiface (sync/clock master) connected to a Fireface UFX (sync/clock slave) with the following routing:
(1) Digiface ADAT Out 1 going to UFX ADAT In 1
(2) UFX Analog Out 3 looped back to UFX Analog In 3
(3) UFX ADAT Out 1 to Digiface ADAT In 1.
Logic's Ping is reporting an latency offset 69 samples. I know from researching the converters for the UFX that the ADC+DAC latency is around 22 samples.
This means that the internal routing of the UFX is adding around 47 samples of latency.
I have been told on this forum that the internal ADAT routing of the Fireface UCX is under 7 samples.
Does 69 samples of additional latency for the UFX running off a Digiface via ADAT sound right. It sounds a bit high to me considering the fast ADAT latency of 7 samples for the UCX.
HDSPe Digiface via ExpressCard Adapter
Fireface UFX III & UCX I
