Topic: How to switch "Listen" Channel back to normal?
Hello folks) Could you help me with this problem? I use Babyface. One day one of two input channels in Total Mix turned blue and a its name changed to "Listen" from AN1. As if I myself named it "Listen", but I didn't. It functions but now I can't adjust some preferences. e.g. I can't monitor input signal. How can I get it normal, without the silly blue colour and a sign (just the change of name doesn't help)? It must be something childishly simple but I still haven't got an idea how I can sort it out. Thanks in advance)
Re: How to switch "Listen" Channel back to normal?
Options menu in TMFX, select "None" for Listenback channel.
Thanks a lot. ??? ?? ????!
