Topic: RME HDSP 9632 outputs problem
Hi, i am new user and owner of hdsp 9632, but i have a small problem.
I use 9632 with some AD/DA Converter for multiple outputs, i need it for good monitoring - Adam Monitors, Yamaha, and also B&W speakers.
Adam Monitors are connected to Analog 1-2 output (RCA), Yamaha - ADAT 1-2 and B&W - ADAT 3-4
The problem is...when i set in DAW mixer on the master channel for example ADAT 1-2 output i can hear at the same time sound also from Analog 1-2.
I do not know what is it, maybe routing or something like this but i want to hear sound only from ADAT 1-2 oraz 3-4 etc..
I know 9632 allows to use up to 16 I/O at the same time, but i think is it possible to hear only one pairs of outputs.
So what should i do to set it correctly?
Sorry for my bad english, I hope you understand my problem.
Thanks in advance!
Re: RME HDSP 9632 outputs problem
please provide jpg screenshots of your mixer and matrix.
3 (edited by Rahman80 2012-11-26 19:13:24)
Thanks for fast answer!
Ok here is screenshot of mixer/matrix:
[img align=C]http://img822.imageshack.us/img822/2231/rmeae.jpg[/img]
It is situation when i change output in DAW mixer to ADAT 1-2 but also Analog 1-2 is active.
If you click in the bottem row faders you see what is send to that output. In the screenshot AN1/2 is selected and as you can seeeverything is send to that output. So select an output by clicking on it in the bottem row and only open the faders of the first and second row you want to hear on an 1-2. Then click on the adat1-2 group output and see what is send to that one. Etc.
Once you get it (it a subgroup mixer with 5 stereo subgroups, you can select in the bottem row) it is easy.
Good luck!
5 (edited by Rahman80 2012-11-26 20:23:45)
Thank you for advice but sorry i do not understand it
Do you mean a window like this:
[img align=c]http://img543.imageshack.us/img543/8255/rme1g.jpg[/img]
If I click on the items A 1+2, the signal appears also on channel AN1 +AN2, but i would like to set only for signal from A 1+2 (ADAT), maybe set it incorrectly...
I hope  understand rightly..
