Topic: Babyface Unbalanced Input w/ baad Noise
Ok, here's the problem:
I experience very bad, clearly audible noise when the input gain on the unit is cranked up to about 90%. Normally, this shouldn't happen.
This is how the background story goes:
I am trying to use the Babyface Preamps to amplify a phono signal, which for archiving purposes I need to record 'flat' (no equalization -> the records in question are from the pre-RIAA-era, so they need to be analysed for distortion curves and will then be eq'ed digitally).
This is the setup:
Fujitsu Lifebook AH530
Win 7
RME Babyface (duh;)
Sommer RCA Cables
RME Unbalanced Breakout Cable
Stanton STR8-150 turntable drive (fyi: it has a built-in ground switch)
I am able to reproduce the Problem on 2 identical systems. Hooking up the Babyface to a different laptop model reduces the noise somewhat, but it's still audible.
At first I thougt the noise came from the power grid (I am currently in a middle east country), but we have an online-uninterruptible power supply ('clean' power directly from the battery) set up and running.
The problem even persists when the laptop is running on batteries (power supply unit disconnected), and I have no sources at all connected to the breakout cable whatsoever.
Also, the noise occurs when I hook up XLR to RCA-cables (yes I know, those aren't good, I'd never use them in a permanent setup) to the balanced breakout box.
The problem does not occur when I set up the balanced breakout box and connect the turntable through a Sonifex Redbox RB-PA2 balanced out Preamplifier. Only problem then is the Redbox built-in RIAA-Curve, which I actually do not want.
This all does very much sound like the USB-Port of the Laptop is interfering with the Babyface Inputs, or am I missing something?
I am going to try routing the unbalanced signal through a Palmer-PLI02 DI-Box to the Babyface symmetrical Ins, but this will take a couple of days at least, since the units are not at my disposal atm.
So, just to be sure: is this a known issue at all? (yes I've tried the 'Suchfunktion', but could not find any entries describing a similar situation). Are there any other factors I might have to take into account?
Sam
PS. One more thing: I am using Audacity for digitizing the records. I know it doesn't support ASIO, but it serves my needs. The Hum/Noise is audible and visible both on the device itself as well as in TotalMix. It peaks at about -32.5dB when the unit's gain is set to about 80-90%. Normal ground noise (through balanced inputs) at this gain level is at about -56dB, which is barely audible.
