Topic: And about buffer size again.
Hello RME Community,
I’m exploring my new UFX usb device. The impression is mostly positive. Just wondering if there’s any material reason to limit the buffer size to 2048 samples at 48 kHz. So far the only explanation I’ve seen on the forum is that a larger buffer size doesn’t make sense. Not very convincing. It makes sense for me. My older Cubase projects work fine with E-mu 0404 usb but with UFX they seem to suffer from clicks and dropouts. Yes, there’s plenty of vst’s and fx there, but I used to manage fine increasing latency in E-mu asio driver. As for UFX, I just press against 2048 samples and it’s not enough.
My system is not that bad:
HP Pavillion dv7 4050er:
Microsoft Windows 7 Home Premium Service Pack 1
QuadCore Intel Core i7-720QM, 1733 MHz (13 x 133)
8128 Mb (DDR3-1333 DDR3 SDRAM)
2x Hitachi HTS725032A9A364 (320 Gb, 7200 RPM, SATA-II)
ATI Mobility Radeon HD 5650 (1024 Mb GDDR3)
Atheros AR9285 802.11b/g/n WiFi Adapter
Realtek PCIe GBE Family Controller
IDT 92HD81B1X @ Intel Ibex Peak PCH - High Definition Audio Controller [B-2]
Chipset: Intel Ibex Peak-M HM55, Intel Lynnfield
Bios: Insyde EFI (F.29)
Cubase 5.5
Tried disabling pretty much everything: ACPI Battery, validity sensor, webcam, onboard soundcard, wifi adapter, net card. UFX is the only device on the usb bus.
DPC Latency Checker says my machine is fine.
Firmware: USB 352, DSP 151, FireWire 341
Driver: 1.0.28.0
So should I just hang myself for spending 2.5k$ on a device that has more limitations than a device for 150$?.. Or I can hope for the improvements in future firmware updates? It’s not just my problem, you know, you keep getting this question.
Sincerely,
Ivan
