Topic: Input to Output Pass-through
If I route one of the hardware inputs to one of the hardware outputs in TotalMix, does the audio signal pass through the AD/DA converters?  Or does the analog signal route directly from the input to the output?
Is there a way to route the input to the output without hitting the converters?
Thanks.
Re: Input to Output Pass-through
All routing in TM is digital, no other way.
Got it.  Thanks for the quick reply!
