Topic: Firmware update problem
Firmware history for Multiface ( Nuendo Audiolink 96) ?
I tried to upgrade to 18 as the toll shows current as 17 but always says "fail"
Any help much appreciatted !
Dimitrios
RME User Forum → HDSP(e) series → Firmware update problem
Dimitrios
Firmware is for the interface card, not the MF. Please provide more details.
The Revision of my multiface ( Nuendo audiolink 96 ) says 17 .
When I run the exe for upgrade it says revision 17. When I try to upgrade it always says fail
I wonder if 17 is the last ever made or the 18 as it is says in text for HDSP firmware upgrade version is the one needed to get upgraded to.
Thanks for supporting.
Dimitrios
OK.
Soi my question is. Is there a firmware upgrade for multiface aka Nuendo Audiolink 96 ?
When I try to upgrade with HDSP firmware upgrade it identifies a firmware numbered 17.
So i7 is the last ever made or is there any newer ?
Thanks for the quick response !!!
Dimitrios
v17 is the current firmware for the card, you are already up to date.
thanks !!
