Topic: how to record in logic the fx return like reberb and echo to total mx
hello,
i'd would like to record the fx (reverb and echo) in my input 1 to logic 9.
what is the manipulation for recording this fx in the record ?
because when i record the effects don't be recorded at the same time !!
Thanks for your response.
Best regards.
Re: how to record in logic the fx return like reberb and echo to total mx
You do this by using the loopback function of TMFX (look for "Recording a Submix - Loopback" in manual)
Basically you select an unused submix in TMFX, mix the signal(s) you want to record (e.g. raise the input 1 volume from the top row, and fx return from the submix on the bottom row) then turn on Loopback from the submix settings (the wrench icon).
When you turn the loopback on, then instead of getting the (pre fx) signal directly from inputs 1/2 to logic, logic will now be recording the signal from TMFX output/submix AN1/2!  If you want, you can keep recording the dry input 1 to logic (with loopback off), and record the wet fx signal to a different stereo track on logic to be able to adjust the fx level later. Simply reset one unused submix in totalmix, turn fx return up and loopback on on that submix, and record that submix with logic to a different stereo track.
thanks for your response, but in logic what input i have to put for recording the input harware 3 for example.
i put the fx return to 0.00 in hardware input 3 and what else ?
the output hardware is AN1/2 ....how can i record the fx in logic ?
I'm a newbie in mixing ;(
thanks for your response !!
i successfully record the fx in logic, thanks very much for your help !!
