Topic: I need firmware 115 to FF UC for Windows. Is there a chance?
Hello!
I need firmware 115 to FF UC for Windows. Is there a chance? Last update is not good for me because my computer freezes UC startup.
RME User Forum → FireWire & USB series → I need firmware 115 to FF UC for Windows. Is there a chance?
Hello!
I'd asked for a quick indication of where I can download firmware 115 to UC
Please, I really can not work!
Did you make sure the UC is in PC mode?
Everything was fine until I updated the drivers and firmware. I just would like to return to the previous state. And what does "PC Mode"?
Double click the encoder button while the unit is not connected via USB. AP on the display means Apple mode.
I changed the PC mode. Unfortunately, there are no results. The computer does not start. Display "loading windows xp" is not active until you remove the USB connector.
Could I have this firmware 115? I checked on another computer. The sound flies like a changed sample rate. There are also noise. Before changing the software, everything worked as it should.
https://archiv.rme-audio.de/download/fu … in_115.zip
Thank you very much, as soon as I get home I know that helped.
I'm desperate. I still do not work, if I could ask more Technical Assistance for pasting a link with these drivers that were to firmware 115? I'm so sorry for the inconvenience. Install a fresh copy of Windows yet. It can help ...
https://archiv.rme-audio.de/download/dr … n_1027.zip
https://archiv.rme-audio.de/download/dr … n_1025.zip
I don't know how to thank you. Everything was back to normal. Once again, thanks a lot!
You should invest the time to find the exact cause. Go back to the higher driver version number without the flash update step by step. What Windows version is in use?
I'm using Windows XP SP3. I had a previous firmware 115 and the newer driver. Unfortunately, my computer crashed.
