Topic: Fireface 400 Audio Problem since System Update with TimeMachine
Hello Support
2 Weeks ago i've reinstalled OSX Mountain Lion on my macbook pro and reinstalled everything all datas from my TimeMachine Backup.
Since then I have only mono-sound on my Mac. I've done the following since then:
- removed all drivers
- repaired all permissions
- reinstalled the latest drivers (also Firmware)
No luck: I still have only mono-sound on head-phones and speakers. I also have a PC with HDSPe AIO where I can compare the sound-quality.
Is this a software-Problem which can be solved or is the analog-to-digital converter inside FF400 broken? Can you help please.
I have a macbook pro and I first realised the problem while I tried to use panning in Logic Pro which worked very good before the update.
I do not use Bus-Power.
