Topic: S/PDIF input using ADAT2
I'm trying to record guitar using a Two Notes Torpedo LIVE Digital Loadbox. It has a S/PDIF digital coax out which will provide 2 tracks of guitar, a wet track and a dry track, which would be incredibly beneficial to me. Anyway, I just ordered a spdif coax to optical converter box from Amazon so I can can connect it to the RME using the TOSLink cable into ADAT2. Is there anything I need to set to get that to work or is it automatic? And if it is not automatic, where does it need to be set?
I have looked at the FF USB Settings dialog but the only input setting I see is under AES Input Source. And the only SPDIF that is mentioned is under ADAT2 Output. Do I need to touch anything or will my RME automatically detect and lock to the sample rate coming in from the LIVE(48 or 96 is what it outputs)?
