Topic: Digi 9652 annoying sample rate problem
I'm using a Hammerfall Digi 9652, not HDSP, under Windows XP. I usually record at 88.2 kHz using S/MUX mode. The 9652 keeps resetting itself to 44.1. It happens whenever I do anything on the computer such as opening a folder. It happens with both Cubase and Reaper. It happens whether the 9652 is synced to ADAT input or word clock.
Does the word clock input operate only in one-half sample rate mode? Is there a jumper to change it?
