Topic: AES 32: can i connect directly the Ouptut 1&2 in one of the AES input?
I want to be able to broadcast the sound of my Vitual Piano, using the tool "Butt" and Icecast server.
Unfortunaly, "Butt" permit to select only "input" device. So, i can select the AES Input, but not the Hammerfall DSP ouput.
Can i connect the AES1&2 clinch Output in one of the AES Input directly ? To create a loop with the digital signal.
Is there a risk to dammage the card ?
To do this:
http://img15.hostingpics.net/thumbs/mini_965689IMG1812.jpg
Re: AES 32: can i connect directly the Ouptut 1&2 in one of the AES input?
No risk, but you can also use the HDSP mixer's internal loopback, see manual.
Thx a lot, it works perfectly ! smile
