Topic: Using Totalmix to mix thru external digital h/w and back into DAW
Hi, I'm sorry to post this but after much reading and searching I cant quite find a solution. If you could point me to a youtube video that would be perfect thanks.
I am using a babyface with Logic. I want to send my mix out through ADAT 3/4 to my TC Finalizer. Then I want to send the audio from the Finalizer back to ADAT IN 3/4 (or 5/6 doesnt matter), into my DAW.
I want to be able to hear the original mix (ie sound going to finalizer) and then switch to the processed input (ie hear the sound coming in from the TC Finalizer).
At the moment no matter what I do I cant hear the signal coming into the DAW from the Finaliser.
Appreciate any help from someone who is doing this already -thanks!
[the reason I am doing this is that I have some nice analogue EQ/Compression on the Finaliser inserts, and I am using the finaliser as the DA/AD. Perhaps this is a bit mad and I could bypass the Finaliser by going analogue out of babyface, and then coming back into analogue in on babyface thus using the babyface DA/AD convertors. Any thoughts on this appreciated]
