Topic: Problem with buffer size
I'm a new owner of a RME firefce UC and i have a problem with buffer size.
I can configure the buffer size to 512 ou 1024 sample and i can lauch "total mix" without any problems. I can play instrument and have direct monitoring ect...
BUT, if i lauch a DAW (like Cubase 5 or Pro tool 9), i have some type of meter peaks in the playback channels of the daw (center row, represented in total mix). None instruments or sources are connected in any inputs of the sound card. Peaks are discontinued and quite loud.
So, i have tried different buffer sizes and it works fine with values until 256 sample.
Could you help me to unsderstand why i can't use 512 or higher values ? And if do you know more about this phenomena ?
For information, with my previous sound card, digidesign mbox mini, i could use 512 and 1024 sample values without any problems...
MY SETUP :
- Windows 7 premium
- 4 Go ram
- Nvidia 8600 GT
Thank you a lot for all the need you could bring to me.
