Topic: Installed RayDat HDSPe Card, Now Total Mix Won't Open
I have been using the Fireface UFX for awhile, and I added the RayDat card yesterday, installed the drivers, but now total mix won't open.
I was under the impression that total mix covered all the cards and interfaces.
Does anybody know how I'm supposed to be routing the in\outs?
Also I haven't been able to get the card to play back through my daw.  I tried the breakout cable, using the two RCA outputs, then I tried a TOS Link cable from ADAT 1 Out to my Presonus Central station's optical input.    I opened a program called HSDP mix, and I see audio playing back through all the outputs, out to the mains, but again nothing is actually reaching my Central Station.
Re: Installed RayDat HDSPe Card, Now Total Mix Won't Open
HDSP Mix IS TotalMix. The RayDAT does not have analog outputs. RCA is SPDIF In and Out. The Central Station most probably does not read ADAT, only SPDIF. The RayDAT manual explains how to change one ADAT output to SPDIF optical.
Thanks!  Problem solved.  I didn't check the box for ADAT4 to convert to SPDIF.  Awesome!
