Topic: FF400 on bus power + MBP + active charging of battery = CPU runaway??
hi. i am swimming in CPU overload..
i have a 2011 quad core MBP, os 10.6.7, ableton 8, rme ff400 (v2.90)..
this has been ROCK SOLID for me, since i got the machine over two years ago.
last week, on a trip, (for a gig.. argh!!) i suddenly came up against a WALL of CPU usage in ableton live, jumping from the average of ~40 percent usage i get from most of my DSP intensive sets, to 50, 60, 70, 80 ,90.. 120!! percent CPU usage, as measured by ableton ( i think it measures 1 core at a time?? ) this of course results in total signal degradation, stuttering, etc..
so.. after a round of troubleshooting, including SMC reset, trying different power adaptors, replacing the FW cable, using time machine to restore back to known-good install, i have arrived at a couple of scenarios where i can reliably re-create this occurence..
1 - MBP on battery power, ableton running, FF400 connected, set to bus power.. system runs well enough UNTIL i connect the 85w adapter to CHARGE THE BATTERY, 1-3 minutes later, during ACTIVE CHARGING ONLY (not 'battery is full' trickle charge) my system will be effectively useless.
1 - MBP adaptor connected, battery charging actively, live running, FF400 on _AC POWER_.. if i switch the FF400 to BUS POWER.. same thing happens.. in fact i can get it to fluctuate up and down by switching back and forth between BUS and AC power..
so, AFAIK, the two common factors here are the FF400 drawing power from the MBP, and the MBP battery being ACTIVELY charged (orange light, not at the end of charging cycle ) . i managed to play the gig i travelled for by fully charging the battery and running the system on combined AC and battery (green light, 'battery is charged', etc..)
any ideas?? bad battery maybe?? something happen to my FF400 causing it to draw more power than it should?? i don't know why this would affect CPU usage, other than perhaps a looping competition for system resources ? the fans are definately spinning up during this process..
any help would be appreciated!! it's not an easy thing to bring into the apple store and get them to replicate, w/o leaving them my fireface
