Topic: Problems with ADAT output on AIO card
Hi all,
I recently purchased the RME AIO card, to use in my Mac Pro running Mountain Lion. I updated the card with the latest firmware, and installed the latest drivers. Also, I purchased and installed the optional Word Clock Module as well.
I am trying to output audio from my Mac Pro via the optical ADAT port of the AIO card, and input the ADAT stream into my Apogee Quartet.
To start with, I connect the WC Out on the Quartet, to the WC In of the AIO (optional WC module). Going into HDSPe settings, I set the Clock Mode to Auto Sync, and the Preferred Sync to "WC/TCO". The System Clock section then shows Mode as "TCO Slave", and the proper frequency of 48000Hz.
I open TotalMix, and set Monitor Main to "A1+2". When I start playback of audio on my Mac Pro, I only see the level readings bar displayed on the AN1 & AN2 outputs; nothing on A1 or A2. I guess what I am asking is, what do I have to do to "activate" the optical output so I can output the ADAT signal?
Thanks in advance for any help.
